pfeatherstone
Dec 22, 2021Guide
Orbi Router(RBR50) satellite dropping internet connection
I'm afraid I dont have a degree in networking but I can tell you that my Orbi Router(RBR50) continues to lose internet connection from one of the satellites. Drops for 10-15 seconds multiple times...
Dec 22, 2021Guru - Experienced User
Its only when connected to one of the satellites?
Have you tried swapping satellites (power off the other one) to see if you can narrow it to being a specific satellite?
- pfeatherstoneDec 22, 2021Guide
My wife uses satellite downstairs for work and has no issues, I should change over to also test but don't want to risk inflicting issues I have on her!!
- plemansDec 22, 2021Guru - Experienced User
If you shut the one down that you're using, does it experience drops?
Again, just trying to figure out if its a specific satellite issue.
Have you tried moving your satellite around? Or factory resetting and reinstalling it?
