Bandito
Nov 17, 2018Luminary
Orbi Routing Problem
I ran into a really weird problem my RBR50 yesterday. It stopped routing packets to my fixed IP address components. I have DHCP set up to issue x.x.x.11 - .199 addresses and then have several camer...
Nov 18, 2018Guru - Experienced User
What is the Mfr and model# of the ethernet switch if one is in the configuration.
I presume static IP addresses are set ON the devices and not the router correct?
Try setting a 192.168.1.100 to .200 IP address pool size then use the IP addresses at the front of the pool and test. I'm using this kind of configuration and have 3 cameras, NAS and 3 printers set for static IPs on the devices. No issues seen.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
After FW was updated, has the Orbi system been powered OFF for 30 seconds then back on or a factory reset and setup from scratch?
- BanditoNov 21, 2018Luminary
The modem is not the issue. If I connect directly to the router (via WiFi) I get a full speed connection. It is only when I connect to the one satellite that the connection slows.
It happened again today after about four days of running normally, when I went to download app updates I noticed that they were slow. A speed test showed the satellite at a max download of 25 Mbps when it should have been 300 Mbps. I checked both the router and the other satellite and they were fine.
Everything was updated and set up per Netgear’s recommendations. I have no plans of disabling the advanced features that provide the high-speed throughput that the Orbis are known for. That makes no sense. If Netgear can’t make the features work as advertised, then they should refund our money.
I’m thinking that the problem with not routing to the fixed IP addresses was a crazy fluke, but the speed degradation is definitely an ongoing problem that I wish could be fixed.
- BanditoNov 23, 2018Luminary
Out of continued frustration with the Orbi system, I went out and picked up an eero system with three of their full second generation routers. I set it up in the same locations as the Orbis were and proceeded to test it out. Unfortunately, it doesn’t work nearly as well as the Orbis. From the same positions that I normally use many of my devices, I was only getting about ⅓ the speed of the Orbis. So, where I would normally get my full Internet speed of 300 Mbps, I was only able to get a little over 100 Mbps from the eero system. Ouch!
Needlees to say, the eero system is going back and the Orbis are back online. Perhaps I’ll have to invest in a timer to regularly reboot the satellite for me before it flakes out on its own. I really wish that the Orbi system was more stable.
I forgot to mention one other thing that I noticed with the eero system. When connecting to the network, the connection was almost instantaneous. The WiFi symbol would pop up immediately. On the Orbi system it takes between 5-10 seconds to make the connection. Significantly different.
