mprogers
Sep 13, 2020Aspirant
Orbi RSR40 - Fast Wired, Slow WiFi
I've got an ORBI RBR40 (although that wasn't an option in the Model pulldown menu), with 2 satellites. My internet provider's modem connects to my Orbi. When I connect to my Orbi via Ethernet...
Mstrbig
Sep 13, 2020Master
Who is your ISP and what equipment did they provide?
What is the current firmware on your Orbi device?
What device is your Orbi router connected to?
Are your satellites wired or wireless?
Try these settings:
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BEAMFORMING, MU-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
mprogers
Thanks for your response. I updated the firmware according to Orbi's instructions, and now I have a link rate of 192 Mbps. However, now that I look at them, ... my other devices Apple devices have much faster link speeds -- 866, 390, 650, 780, 650, 866.
Those aren't 940 Mbps, so I guess that's the cost of WiFi, but only my iMac is really dragging. It seems to be an iMac <-> Orbi problem at this point.
- MstrbigSep 13, 2020Master
mprogers wrote:Thanks for your response. I updated the firmware according to Orbi's instructions, and now I have a link rate of 192 Mbps. However, now that I look at them, ... my other devices Apple devices have much faster link speeds -- 866, 390, 650, 780, 650, 866.
There has been much discussion about iMacs having slow WIFI. You could check your iMac WIFI settings to see if "A" it is a Wireless N /AC card and "B" you settings are optimum. The reported work around is to purchase a USB WIFI dongle with better specs.
