crvance003
Apr 18, 2020Aspirant
Orbi RSR50 firmware 2.5.1.16
I just updated my Orbi RBR50 router to the latest (as of 04/18/20) firware version, 2.5.1.8. When it was done, orbilogin.com indicated that my satellites, all RBS50, were all updated to 2.5.1.16. The...
- Apr 18, 2020
NG sometimes pushes FW udpates before they post them on the web site.
crvance003 wrote:I just updated my Orbi RBR50 router to the latest (as of 04/18/20) firware version, 2.5.1.8. When it was done, orbilogin.com indicated that my satellites, all RBS50, were all updated to 2.5.1.16. The thing is, I can't find on netgear.com a downloadable version of that satellite firmware. There IS a version 2.5.1.16 for the RBS20, but the latest listed version for the RBS50 is 2.5.1.8. My question, then is, what's going on? Is it that my system is misidentifying the firmware version of the satellites? OR did my router force a RBS20 firmware on my RBS50 satellites? OR is there a "secret" 2.5.1.16 version for the RBS50's? Any insight from the community would be appreciated.
CrimpOn
Apr 18, 2020Guru - Experienced User
I would appreciate hearing "how" this firmware update was done:
- Using the "Firmware Update" menu item on the Advanced Tab, Administration?
i.e. the web page showed that 2.5.1.8 was available for both router and satellites?
and you then clicked on "Do it" (or whatever the button is)? - The Orbi app?
If the Firmware Update page says that 2.5.1.8 is available as an update, then (silly old person) I think that's what should be installed. I am seriously not comfortable with:
FURRYe38 wrote:NG sometimes pushes FW udpates before they post them on the web site.
We have become comfortable with the concept that Netgear NO LONGER "pushes" firmware unless there is a SERIOUS URGENCY to do so. Going from .8 to .16 on the satellite does not sound "urgent".
MY TAKE on this is that someone at Netgear may have made a "silent revision" to 2.5.1.8, but screwed up and updated the version number in a text field without intending to. Of course, with Netgear, we'll never know.
crvance003
and you then clicked on "Do it" (or whatever the button is)?- The Orbi app?
Checking for a fw update on my router's web page erroneously told me that there was no update available. Instead I download the fw updates from the NG website and then manually updated my router using its web page (Advanced -> Administration -> Firmware Update -> Manual Update). Apparently just selecting the router to be updated to 2.5.1.8 convinced NG to also push the fw on all 5 of my satellites to 2.5.1.16, without my asking.
- CrimpOnApr 18, 2020Guru - Experienced User
crvance003 wrote:
Checking for a fw update on my router's web page erroneously told me that there was no update available. Instead I download the fw updates from the NG website and then manually updated my router using its web page (Advanced -> Administration -> Firmware Update -> Manual Update). Apparently just selecting the router to be updated to 2.5.1.8 convinced NG to also push the fw on all 5 of my satellites to 2.5.1.16, without my asking.Oh, my. So, the only Manual Update that you actually did was to the router, not to any of the satellites?
- crvance003Apr 18, 2020Aspirant
Well, in all fairness, I was going to update my satellites after the router. NG just simplified the process for me without my having to take those additional steps.
- tomschmidtApr 19, 2020Virtuoso
FYI, there is a v2.5.1.16 firmware release in beta. However, it should not have been released to anyones systems yet unless something was messed up in NGs firmware update repository. I do not know what changes are in this minor update.
