Atobro
Jul 12, 2019Aspirant
Orbi running slow after replacing modem
We our having speed issues since our home was hit with a power surge. The modem was replaced by ISP and have confirmed through testing that the speed coming into the house is full speed (over 400mbps...
badbet
Jul 13, 2019Aspirant
I doubt this helps but I’m with spectrum, using an rbr50 and satellite, experiencing exactly the same issue. Unfortunately, I haven’t come across a solution that doesn’t involve getting a new/different router :(
- FURRYe38Jul 13, 2019Guru - Experienced User
What is the Mfr and model # of the ISP modem the Orbi is connected too?
What are the stats seen on your Orbi for the WAN and LAN sides? Most ISP Modems support 1000Mbps on the RJ45 ports.
Ensure your using a good quality LAN cable between the ISP modem and RBR.
Power OFF both Orbi and ISP modem for 1 minute. Then power ON the ISP modem and let it sync, the power ON the RBR. Check stats for speeds on the WAN and LAN ports.
Try a different modem if possible.
