David152
Apr 26, 2023Aspirant
Orbi S50
The main router of the Orbi S50 started blinking white, I’ve tried all the recommended methods to fix it, rebooting using the restarted button etc but there is no wifi signal that I can connect to to...
KevinLiT
Apr 26, 2023NETGEAR Moderator
Hello David152 ,
Welcome to the NETGEAR Community!
I understand that you are having issues with your RBS50. The flashing lights are an indication that the satellite firmware may be different than the router. Please log into your satellite and ensure that it is on the current firmware version 2.7.5.4. If it is not please manually update your satellite to the firmware version 2.7.5.4. Please be sure to select the firmware under RBS50 from the attached link.
For step-by-step instructions on how to manually update your RBS50 please navigate to the link below:
How do I check and manually update the firmware on my Orbi satellite? | Answer | NETGEAR Support
Navigate to the link below for the download file for your RBS50:
https://www.netgear.com/support/product/RBK50#download
Best,
Kevin
Community Team
