ouloveme
Oct 01, 2023Aspirant
orbi same network not be able to reach each other
My computer is connected to the main RBR50, My printer is connected to RBR40 same Wi-Fi network and the IP address is in the same range but I"'m not able to connect to my printer.
CrimpOn
Oct 01, 2023Guru - Experienced User
ouloveme wrote:
I am not able to connect to my printer.
Does this mean not ever, or sometimes?
This makes a huge difference.
Thanks for clarifying the equipment. Could you look at the Orbi web interface Attached Devices page and see exactly which Orbi device the printer is using? (The Orbi app has this information also, but takes a few swipes to find it.)
- oulovemeOct 01, 2023Aspirant
Sorry for not being clear. yes, it just happened recently. it used to work fine. my printer right now it's connected to RBS50. I'll try to reset all Orbi devices and try to do the new setup.
thanks for all the help.
- CrimpOnOct 01, 2023Guru - Experienced User
An additional test is to attempt to 'ping' the printer or open the printer web page (if it supports that feature - my Epson does).
i.e.
- Open a command window and type ping <ip address of printer>
- Open a web browser and try to connect to the printer http://<ip of printer>
that is when I decided to post it here. I can't ping to my printer with the ip I got.
