emartir
Apr 26, 2020Tutor
Orbi Sat RBS10 blinking red light
Hi guys. Just got the Orbi RBK12 this past Friday 4/24. When I set it up the first time everything worked. The router was active, the satellite RBS10 was recognized and online, updated the firmwar...
Retired_Member
Apr 26, 2020what does this mean....updated the firmware,
how do you do that?
- emartirApr 26, 2020Tutor
automatic update that was pushed through after installation.
- Retired_MemberApr 26, 2020
perhaps the sat is too close to the router.....if you feel you've done a 'reset' on it...you may want to the sat back to where you had it
- lvbrogersApr 29, 2020Initiate
This very same thing just happened to me. I took these sats straight out of the box. Powered them up, got them connected, the app did a firmware upgrade and everything was nice. I decided to do some rearranging after the initial installation so I unplugged them. When I plugged them back in, all 3 of them are blinking red, refusing to be reset.
