emartir
Apr 26, 2020Tutor
Orbi Sat RBS10 blinking red light
Hi guys. Just got the Orbi RBK12 this past Friday 4/24. When I set it up the first time everything worked. The router was active, the satellite RBS10 was recognized and online, updated the firmwar...
Retired_Member
Apr 26, 2020perhaps the sat is too close to the router.....if you feel you've done a 'reset' on it...you may want to the sat back to where you had it
lvbrogers
Apr 29, 2020Initiate
This very same thing just happened to me. I took these sats straight out of the box. Powered them up, got them connected, the app did a firmware upgrade and everything was nice. I decided to do some rearranging after the initial installation so I unplugged them. When I plugged them back in, all 3 of them are blinking red, refusing to be reset.
- emartirApr 30, 2020Tutor
I tried the live chat throught the app. Was asked a ton of questions, at the end was told to call the 800 number for tech support. So i called the number, bunch of questions again, then proceeded to perform the reset steps. First was a 12 second reset, nothing red blinking light, then the 30-30-30 reset, nothing red blinking light. The support technician told me to return it to the store I purchased it from and get a new one. Great. Of course the store is out of stock. I may get the Orbi Nighthawk instead (router and satellite combo), but let me see if they have the same issues as this one.
- FURRYe38Apr 30, 2020Guru - Experienced User
I would make contact with NG support and ask for help and information regarding this.
lvbrogers wrote:This very same thing just happened to me. I took these sats straight out of the box. Powered them up, got them connected, the app did a firmware upgrade and everything was nice. I decided to do some rearranging after the initial installation so I unplugged them. When I plugged them back in, all 3 of them are blinking red, refusing to be reset.
