DNielsen
Jan 13, 2022Aspirant
Orbi Satelit loosing connection - Ethernet Backhaul connected
Just got a RBR750 and RBS750. The RBR in the main house works fine. But I seems to have issues with the RBS750, which is in the workshop. They are backhaul connected via ethernet cable. Fro...
Jan 13, 2022Guru - Experienced User
Be sure the RBS is ethernet connected using the following:
Be sure your using good quality LAN cables. CAT6 is recommended.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
