chrisxpierce
May 20, 2020Tutor
Orbi Satelite Connecting/Not Connecting Devices
I have the AC2200 Orbi Mesh. With two satelites. My devices are connecting to my main router, and not the satelite that is much closer...specifically, one of my Blink Cameras...the camera is indica...
May 21, 2020Guru - Experienced User
It's up to the client devices to pick and choose which signal they connect too. You can help this some by turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
chrisxpierce wrote:I have the AC2200 Orbi Mesh. With two satelites. My devices are connecting to my main router, and not the satelite that is much closer...specifically, one of my Blink Cameras...the camera is indicating poor wifi, because its connecting to my the the router, instead of the satelite, that has full signal (green light). Any ideas, is there a way to get these devices to connect to the closest satelite, or should i say, have the satelite connect to the device because its closer? Thanks in advance.
Chris
chrisxpierce
May 21, 2020Tutor
Great information as well... Makes sense. THANK YOU!!! I have it at 100%
- FURRYe38May 21, 2020Guru - Experienced User
Yes, turning that down will help steer the devices to RBS...
- tomschmidtMay 21, 2020Virtuoso
For me, reducing the power of the 2.4GHz signal did not help overall. I had to reduce it to 25% before my garage would not detect it from the router. However that then affected all other 2.4GHz devices, they also got too weak of a signal to function. Your mileage may vary, you can test different power levels to see if one works for your environment.
- chrisxpierceMay 22, 2020Tutor
It would appear that reducing the power to 50%, is helping at the moment, I'll keep you guys posted. Thanks for all of your help!
- FURRYe38May 22, 2020Guru - Experienced User
Good to hear. Adjust it as you need too.
chrisxpierce wrote:It would appear that reducing the power to 50%, is helping at the moment, I'll keep you guys posted. Thanks for all of your help!
