GASkinner
Apr 23, 2019Tutor
Orbi Satelite keeps loosing connection with router
I have been using Orbi for 2+ years now, generally no problems.
For no obvious reason my satelitte has started randomly loosing connection with the router and the ring turns magenta.
Both the rou...
GASkinner
Apr 23, 2019Tutor
Just did the .48 upgrade, I always keep up to date.
Understand the notion of "just because it was working doesn't mean it was working well".
What would an optimal distance be between router and satelite. My setup has always been router on the ground floor and satelite on the 1 st floor. The direct line of sight distance is 25 ft with not even a wall between the two.
Apr 23, 2019Guru - Experienced User
30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. The router alone can cover up to 1100-2000sq feet on it's own. Wifi overlap is key here as well.
Router should be on main floor or 2nd floor. Satellite on main or uppor or basement. Mine is setup with Base on 2nd floor and satellite on main floor 40 feet in between. No issues.
- GASkinnerApr 23, 2019Tutor
Ok, I'll try different locations for the satelite.
I have no choice for router location because of the Bell modem location with those 2 wired.
I'll try put the satelite more in the center of the 2 nd floor, which will increase the distance slightly but also puts a wall between the two.
- FURRYe38Apr 23, 2019Guru - Experienced User
You can always move the base orbi with a longer cable between the modem and orbi, if needed. :smileywink:
Be sure that the wifi on the modem is turned fully OFF if it's not already.
I have a roof and 1 wall between my orbi and satellite. :smileywink:
Interesting, it is more robust than I thought then.
QQ - do you have any outside coverage? I have a pool area out the back of the house (distance approx 60ft from router 40 from satelite) and the signal strength is very poor, almost unusable. I was thinking of adding another satelite to cover out there. Thoughts?
