tubphooj
Jun 03, 2020Tutor
Orbi Satelite keeps renewing IP of ethernet connected devices
i have a RBR50 and RBS50. as of late, my satelite keeps re-assiging IPs - over and over again, at least thats what it looks like on the logs. as a result, the two devices that are connected thro...
Jun 04, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
tubphooj wrote:i have a RBR50 and RBS50.
as of late, my satelite keeps re-assiging IPs - over and over again, at least thats what it looks like on the logs. as a result, the two devices that are connected through ethernet cables keeps dropping connection - everytime i lose connection, i check the logs and sure enough, DHCP IP assignment. 1 is a desktop and the other is a Aruba VPN Switch that i use for work. i even reserved the Aruba to an IP address x.240 but it continues to happen. updated all my firmware, currently V2.5.1.16. reboot many times, only thing i havent done is factory reset, which wont do any good because it'll just reupdate the firmware right? i am getting really frustrated with this issue. please help. any idea why its doing this?
i've not noticed any devices connected through wifi drop connection. is there a setting on Orbi that i can extend length of when it does this madness?
[DHCP IP: 192.168.1.25] to MAC address 70:85:c2:fxxx, Thursday, June 04, 2020 00:35:04
[DHCP IP: 192.168.1.240] to MAC address 20:4c:03:axxxx, Thursday, June 04, 2020 00:34:34
[DHCP IP: 192.168.1.25] to MAC address 70:85:c2:f2:8xxxx7, Thursday, June 04, 2020 00:34:33
[DHCP IP: 192.168.1.25] to MAC address 70:85:c2:f2:xxxx7, Wednesday, June 03, 2020 20:56:11
[DHCP IP: 192.168.1.18] to MAC address c0:9a:d0:c3xxxx, Wednesday, June 03, 2020 20:55:58
[DHCP IP: 192.168.1.25] to MAC address 70:85:c2:f2xxx27, Wednesday, June 03, 2020 20:55:41
[DHCP IP: 192.168.1.240] to MAC address 20:4c:0xxxxff:fe, Wednesday, June 03, 2020 20:55:16
[DHCP IP: 192.168.1.25] to MAC address 70:85:c2xxx27, Wednesday, June 03, 2020 20:55:14
[DHCP IP: 192.168.1.240] to MAC address 20:4c:0xxx:ff:fe, Wednesday, June 03, 2020 20:54:53
[DHCP IP: 192.168.1.25] to MAC address 70:85:c2xxxx7, Wednesday, June 03, 2020 20:54:31
[DHCP IP: 192.168.1.18] to MAC address c0:9a:d0:c3xxxx:6a, Wednesday, June 03, 2020 20:53:18
[DHCP IP: 192.168.1.39] to MAC address 2c:f0:ee:0xxxxx:7a, Wednesday, June 03, 2020 20:52:55
