tubphooj
Jun 03, 2020Tutor
Orbi Satelite keeps renewing IP of ethernet connected devices
i have a RBR50 and RBS50. as of late, my satelite keeps re-assiging IPs - over and over again, at least thats what it looks like on the logs. as a result, the two devices that are connected thro...
Lyth
Jun 05, 2020Guide
Ever since I updated to firmware 2.5.1.16 I also have numerous devices that are being reissued the same IP constantly.
[DHCP IP: 192.168.1.20] to MAC address xx:xx:xx:xx:21:06, Friday, June 05, 2020 10:50:01
[DHCP IP: 192.168.1.25] to MAC address xx:xx:xx:xx:ef:b2, Friday, June 05, 2020 10:49:39
[DHCP IP: 192.168.1.20] to MAC address xx:xx:xx:xx:21:06, Friday, June 05, 2020 10:49:26
[DHCP IP: 192.168.1.20] to MAC address xx:xx:xx:xx:21:06, Friday, June 05, 2020 10:49:25
[DHCP IP: 192.168.1.20] to MAC address xx:xx:xx:xx:21:06, Friday, June 05, 2020 10:46:45
[DHCP IP: 192.168.1.20] to MAC address xx:xx:xx:xx:21:06, Friday, June 05, 2020 10:45:45
[DHCP IP: 192.168.1.20] to MAC address xx:xx:xx:xx:21:06, Friday, June 05, 2020 10:44:57
[DHCP IP: 192.168.1.25] to MAC address xx:xx:xx:xx:ef:b2, Friday, June 05, 2020 10:44:38
My logs are full of this every few seconds to every few minutes. It's not just the 2 devices above. It's at least 10 to 12 out of 25 or so devices on our wifi. It doesn't seem to matter if it's a PC, apple watch, or other device. I've never seen this in my logs before this firmware.
Jun 05, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
Please try a factory reset and setup from scratch with the RBR and RBS.
Lyth wrote:Ever since I updated to firmware 2.5.1.16 I also have numerous devices that are being reissued the same IP constantly.
- LythJun 05, 2020Guide
I am guilty of not trying a factory reset to see if it helps. I'll backup my config and give it try sometime this weekend and report back.
- FURRYe38Jun 05, 2020Guru - Experienced User
Be sure to check for this problem before re-applying the back up config.
Lyth wrote:I am guilty of not trying a factory reset to see if it helps. I'll backup my config and give it try sometime this weekend and report back.
- tomschmidtJun 08, 2020Virtuoso
I have two devices (IP security cameras) that likewise are filling my log file with DHCP lease requests every 5 minutes. I have power cycled the cameras and it did not help. Both are using reserved IP addresses outside of the DHCP lease range of addresses. It is odd that two devices of my 35+ devices are doing this. I will try changing their reserved IP address to see if that makes any difference.
YAFOB (Yet Another Frustrating Orbi Bug)
