tubphooj
Jun 04, 2020Tutor
Orbi Satelite keeps renewing IP of ethernet connected devices
i have a RBR50 and RBS50. as of late, my satelite keeps re-assiging IPs - over and over again, at least thats what it looks like on the logs. as a result, the two devices that are connected thro...
MishoA
Jun 08, 2020Tutor
Same issue with me. Did factory reset on my router and sat. Started from scratch same issue. Constant DHCP reassignment
MishoA
Jun 11, 2020Tutor
This is what fixed it for me:
I downgraded my router to V2.3.5.30 and left my satellite at V2.5.1.16 and that fixed the problem, and it has been stable for the past 72 hours, no interruptions whatsoever. By the way, I did try 2.5.1.8 and it didn't do anything (same problem), so that's why I went all the way back to 2.3.5.30. Hope that helps
