Jethro_D
May 18, 2020Aspirant
Orbi Satellite - one computer has no internet, all others fine
I have an Orbi RBR50 running in Access Point mode. I have about 15 connected devices in my home, usually with about half connected to the main router and half connected to the satellite. All devices ...
- May 19, 2020
Something to contact the mfr about. If same thing happens with WPA disabled, then I would get the laptop reviewed.
Jethro_D
Same thing when I disable WPA2 and try connecting.
HP is about 1-1.5 years old.
I'm also beginning to suspect it's a laptop issue. I discovered something very odd. The laptop is typically docked in a docking station, with its lid closed, as I have a dual monitor setup. However, I noticed today while troubleshooting (out of the dock) that I wasn't having any issues whether I was connected to the RBR or RBS. So, back at my docking station, I verified that I was having the issue with the lid closed. Then, I cracked the lid open (just enough to turn on the laptop's display) and suddenly the internet began working as if I had unplugged the RBS. However, I didn't unplug the RBS - just opened the laptop's lid. I verified I was still connected to RBS through the Orbi app, and also ran a speed test and was achieving *much* higher speeds than typical in my office (due to being connected to the RBS and not the more distant RBR).
I've never seen a laptop behave this different when the lid is closed vs. open... very curious.
May 19, 2020Guru - Experienced User
- Jethro_DMay 20, 2020Aspirant
Going to close this one out as 'solved'. I ended up moving my satellite into the same room as my work laptop (HP), and connected the HP to the satellite via ethernet cable. This has completly solved my laptop problems, as well as a host of other USB issues I was having while connected to my docking station. As such, I agree this was an issue with my laptop setup and dock somehow conflicting with my laptop's WiFi adapter, and doesn't appear to be anything specific to the Orbi.
Cheers,
Jethro
- FURRYe38May 20, 2020Guru - Experienced User
Possible faulty wifi adapter. I would get it looked at while you can.
Thanks for letting us know.
Enjoy. :smileywink:
