RudigerGatt
Aug 18, 2018Aspirant
Orbi Satellite Addons
Hey everyone, ive been researching alot about mesh networks, im moving into my home soon which consists of 2 floors. Ive seen a number of reviews and from the looks of it the nergear orbi is the one ...
Aug 18, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
I have a 5000sq ft home and use just the base and 1 satellite with 40 feet in between. Have great coverage and performance.
RudigerGatt
The house is a total of 4000sqm, its not all open plan. If i did buy the 2 system package and needed another satetllite, could i buy any orbi satellite or does it have to be a specific model like my package?
- FURRYe38Aug 18, 2018Guru - Experienced User
It's best to keep similar model satellite to maintain same wifi speeds across the board. However you can connect different model satellites.
