mgdurand1
Dec 02, 2017Luminary
Orbi Satellite and Cat 5 connector - printer?
Hi. Gave an Orbi system to a good friend. Solved their network range problems. However, they tell me that the wireless connection to an Epson printer seems to shut down regularly requiring a reboo...
jerryschwartz
Dec 02, 2017Apprentice
Does the printer even have a wired LAN connection? If it doesn't, then the answer is obvious. If it does, then I guess it would work. I can't promise that there won't be some issues with the Orbi, but the manufacturer probably wouldn't have put an ethernet connector on there if it weren't usable.
mgdurand1
Dec 03, 2017Luminary
Yes. It has a wired LAN connection. Every network printer I have ever seen has one. Do you know of one that does not? I'd be curious to know. I also think it will work but was wondering if anyone had tried it and had it actually work.
