mgdurand1
Dec 02, 2017Luminary
Orbi Satellite and Cat 5 connector - printer?
Hi. Gave an Orbi system to a good friend. Solved their network range problems. However, they tell me that the wireless connection to an Epson printer seems to shut down regularly requiring a reboo...
mgdurand1
Dec 03, 2017Luminary
Yes. It has a wired LAN connection. Every network printer I have ever seen has one. Do you know of one that does not? I'd be curious to know. I also think it will work but was wondering if anyone had tried it and had it actually work.
loomis1975
I have a new HP Envy Photo 7155 network that does not have an ethernet port, wifi only. There are a lot of them now. If you hook them up directly to a computer via USB, you lose a lot of functionality. I have to reboot it once every week or two, as it eventually looses its wifi connection (wifi blue light on printer blinks).
- mgdurand1Dec 03, 2017Luminary
Shows my age! Hard to imagine a network device without a cat5 port, but there you are! Thanks.
- jerryschwartzDec 03, 2017Apprentice
Same with my Canon Pixma, except that you don't lose functionality with the USB connection.
