Rustproofcorn
Jan 04, 2017Luminary
Orbi satellite and genie app
In the genie app sometimes I can see the satellite and sometimes I can't. Right now I'm sure I'm on the sat but the genie app just shows I have port wifi to the router? How can u tell which unit your ...
Rustproofcorn
Mine doesn't have the connection type column. Are u sayinf u had to enable that? But now I can't?
- loomis1975Jan 04, 2017Luminary
Thats right. You can't see that screen anymore unless you enabled it on a debug.htm page from mulitple firmwares back. Its no longer an option. I had that view till I had to do a factory reset to correct some erratic behavior. Once you factory reset on a more recent firmware, there is really no going back.
- swrtwdrvJan 04, 2017Apprentice
You can still get to the screen, but for the connection type only shows orbi, wired, or wireless. Doesn't show band any more. Try this:
Log into Orbi and and click on Attached Devices
Click on any device name to open Edit Device page
Click in device name box
Press the <enter> key on your computer
- rhester72Jan 05, 2017Virtuoso
loomis1975 wrote:Thats right. You can't see that screen anymore unless you enabled it on a debug.htm page from mulitple firmwares back. Its no longer an option. I had that view till I had to do a factory reset to correct some erratic behavior. Once you factory reset on a more recent firmware, there is really no going back.
I posted a very probable workaround for this months ago involving telnetting into the router and setting an environment variable, but to the best of my knowledge nobody tried. *shrugs*
Rodney
