Rustproofcorn
Jan 04, 2017Luminary
Orbi satellite and genie app
In the genie app sometimes I can see the satellite and sometimes I can't. Right now I'm sure I'm on the sat but the genie app just shows I have port wifi to the router? How can u tell which unit your ...
loomis1975
Thats right. You can't see that screen anymore unless you enabled it on a debug.htm page from mulitple firmwares back. Its no longer an option. I had that view till I had to do a factory reset to correct some erratic behavior. Once you factory reset on a more recent firmware, there is really no going back.
rhester72
Jan 05, 2017Virtuoso
loomis1975 wrote:Thats right. You can't see that screen anymore unless you enabled it on a debug.htm page from mulitple firmwares back. Its no longer an option. I had that view till I had to do a factory reset to correct some erratic behavior. Once you factory reset on a more recent firmware, there is really no going back.
I posted a very probable workaround for this months ago involving telnetting into the router and setting an environment variable, but to the best of my knowledge nobody tried. *shrugs*
Rodney
