Rustproofcorn
Jan 04, 2017Luminary
Orbi satellite and genie app
In the genie app sometimes I can see the satellite and sometimes I can't. Right now I'm sure I'm on the sat but the genie app just shows I have port wifi to the router? How can u tell which unit your ...
Rustproofcorn
Jan 05, 2017Luminary
Thanks man!!! It did work like a gem!!! I now can see what's connected ant where with what band it's on. We all are morons.
- rhester72Jan 05, 2017Virtuoso
Very glad to hear it worked! Here's hoping someday it'll be (re)exposed through the normal UI.
Rodney
- swrtwdrvJan 05, 2017Apprentice
Wow. I braved it and found a nice article for us Windows 7 users on how to add the Telnet client to Windows and then use it at: https://www.techwalla.com/articles/how-to-telnet-into-a-router.
Pretty simple then to follow your directions.
Thanks
- thedakJan 06, 2017Apprentice
Can you repost the commands that you use once you have telnet'ed in to enable this?
Thanks!
