Rustproofcorn
Jan 04, 2017Luminary
Orbi satellite and genie app
In the genie app sometimes I can see the satellite and sometimes I can't. Right now I'm sure I'm on the sat but the genie app just shows I have port wifi to the router? How can u tell which unit your ...
Rustproofcorn
Jan 05, 2017Luminary
Thanks man!!! It did work like a gem!!! I now can see what's connected ant where with what band it's on. We all are morons.
rhester72
Jan 05, 2017Virtuoso
Very glad to hear it worked! Here's hoping someday it'll be (re)exposed through the normal UI.
Rodney
- swrtwdrvJan 05, 2017Apprentice
Wow. I braved it and found a nice article for us Windows 7 users on how to add the Telnet client to Windows and then use it at: https://www.techwalla.com/articles/how-to-telnet-into-a-router.
Pretty simple then to follow your directions.
Thanks
- thedakJan 06, 2017Apprentice
Can you repost the commands that you use once you have telnet'ed in to enable this?
Thanks!
