Seattlites
Mar 18, 2017Aspirant
ORBI Satellite cannot connect
No matter what I do and where I place the satellite, even in areas where I have a strong WiFi signal from the base unit, it will not connect and always provides the magenta light. The base unit has ...
Seattlites
Mar 19, 2017Aspirant
Thanks. Reset worked and I was then able to update firmware separately.
TomMac
Mar 20, 2017Guru
good to hear... if you update the software later, it was recommended to me to update the Sat first and then the Main..
Do this by the manual updating option ( download sw to computer first ) and not the automatic method
