StijnJJ
Dec 13, 2021Aspirant
Orbi satellite compatible?
Will AX1800/RBS350 satellites work as extension of network with RBR50 & RBS50?
Dec 13, 2021Guru - Experienced User
I know RBS50s are not wirelessly compatible with AX systems.
Not to sure about in the other direction. I presume no. Something to try and see.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
