jojo2go
Jan 08, 2017Apprentice
Orbi satellite connection does not show up on iPhone Orbi app, but shows up as a connected device
Hi, I have 1 satellite conected to my router. It connects fine (solid blue light), and near it, I have full wifi signal so I know it is active. However, when I look at my Orbi App on my iPhone,...
swrtwdrv
It does the same for me. Orbi app needs work.
Netgear Genie app is better.
- jojo2goJan 08, 2017Apprentice
It appears even buggy in the Netgear Genie (orbilogin.com). In the Genie I see the 1 satellite connected, but when I go to the advanced section -> administration -> firmware, I do not see the satellite there and its firmware. I only see the router and its firmware.....Close to the router I get close to my max 200 Mbps speed (using OOKLA Speedtest), but currently at the satellite (with strong wifi signal), I am only getting about 60 Mbps.... I was getting about my max of 200 Mbps earlier today at the satellite... not sure why the big change now... seem not very consistent...
- swrtwdrvJan 09, 2017Apprentice
Check firmware on Orbi and satellite--they should be the same version. Update if necessary and factory reset the satellite. May need to sync after doing this. This fixes some minor issues.
- jojo2goJan 09, 2017Apprentice
Firmware 1.4.0.34 on both router and satellite.
Comcast 250 Mbps service
OOKLA speed test
Toshiba laptop (Win 10) at router:
(ping/up/down)
Test 1wireless: 19/232/12 (ping/up/down)
Test 2 wireless: 21/230/12
Test 3 wireless: 22/223/12
Test 1 wired to router: 22/96/12
Test 2 wired to router: 24/95/12
Test 3 wired to router: 18/95/12
iPhone 6 at router:
Test 1 wireless: 9/221/12 (ping/up/down)
Test 2 wireless: 10/237/12
Test 3 wireless: 11/236/12
Toshiba laptop (Win 10) at satellite:
Test 1 wireless: 24/79/12 (ping/up/down)
Test 2 wireless: 28/80/12
Test 3 wireless: 29/71/12
iPhone 6 at satellite:
Test 1 wireless: 15/81/12 (ping/up/down)
Test 2 wireless: 13/84/12
Test 3 wireless: 13/76/12
I tried to reboot the satellite to factory reset and re-sync, but get the same download speeds of about 80 Mbps. When I first set this system up, I was getting 250 Mbps at the satellite too.
Why am I only getting < 1/2 down load speed at the satellite?
I do see the satellite in the netgear genie s/w again in the firmware section.
Also log into satellite to see what is attached, or try this:
Log into Orbi and and click on Attached Devices
Click on any device name to open Edit Device page
Click in device name box
Press the <enter> key on your computer (or Go on your iPad)
