anndrewkim
Sep 09, 2019Follower
Orbi Satellite Connection is slow
I have my orbi setup and downstairs where the main one sits, I get 300mbps but I'm only getting 100 with the satellite (wifi and ethernet). Please help.
1 Reply
What is the Mfr and model# of the ISP modem the NG router is connected too?Ensure your speed test device is connected to the RBS and not the RBR befire testing.
What is the Mfr and model# of the ethernet switch if one is in the configuration.What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
