kevincc
Jul 30, 2020Guide
Orbi Satellite Connection Type - Performance Issue
I'm having performance issues with devices connected to my Orbi satellite. I have devices connected to the satellite via wifi as well as wired. I'm only getting about 10Mbps download. It used to b...
Jul 30, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- kevinccJul 31, 2020Guide
I'm not using an ISP modem. I'm using the Netgear CBR40 Cable Modem Router. Firmware for the modem is V2.3.5.12. Firmware for the satellilte is V2.3.5.30. Should the connection type in the screenshot that I provided show 5G for the satellite? I'll try some of the options you listed.
- FURRYe38Aug 07, 2020Guru - Experienced User
Let us know if there has been any progress on this.
