Glassfist
May 27, 2018Aspirant
Orbi Satellite Connection via Ethernet
I am trying to get an ethernet connection through my house built in cables to the satellite while maintaining the wireless output of the orbi router. Is this possible? I thought I could put the m...
st_shaw
May 27, 2018Master
Yes. Setup the system and add the satelites wirelessly first. Once everything is setup, you can connect the satellites by wire to the LAN ports on the Orbi router. It may take 5 minutes or more to stabilize.
Glassfist
May 28, 2018Aspirant
Thanks. I think it's working after some blue and magenta color swaps... the network map still says wireless though (dotten line from router to satellite)
- st_shawMay 28, 2018Master
Good. It sounds like you are using the app. Try logging into the Orbi router GUI using a web browser and look at the "Attached Devices" page there. It may give you a more accurate report on how the satellite is connected.
The attached devices report has not always been accurate in various firmware releases.
