Easthoju
Jun 30, 2018Follower
Orbi Satellite Connection via Ethernet
I have an Orbi system with one satellite. I wish to extend the coverage to my garage which is 60 metres away - too far for any connection via WiFi. I would therefore like to use an Ethernet cable to ...
Jul 01, 2018Guru - Experienced User
Possible that he could LAN connect a 2nd satellite/AP to the 1st satellite, wired back haul to the garage. Ya, No expereince in this configruation. Possible though. I don't think the actual Daisy Chain feature is needed since it would all be wired and not wireless. If he LAN connected the 1st satellite, then did the same with a 2nd satellite in the garage, should work. Would need a Orbi satellite, could use a less expensive NetGear EX unit configured for AP mode. EX7700 or EX8000.
