SSJDUSTEN
Aug 29, 2018Aspirant
Orbi Satellite Connection via Ethernet
Hey everyone. First time post. I just recently got the ORBI system along with the CM1000 for my modem. The router is in the office and the satellite is in the living room. 50 feet apart or less line ...
Aug 29, 2018Guru - Experienced User
What FW is currently loaded?
Might try moving the satelite closer and see. Try 40 feet?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
SSJDUSTEN
Sorry I am usually a stickler for details myself.
Latest firmware. 2.4.1.16 I believe?
1100 square feet Honesty nothing huge by any imagination. Auto for 2.4 ghz, and 48 for 5.
Quite a few wifi neigbors actually.
Where do those adjustments live in the setup menu? I may need a little explanation as to what to adjust on the settings. Such as Daisy Chain, and IPV6. I switched the Satellite so it has a lan cable running to the Xbox. Any thoughts on that.
If you change it for the router, does the satellite get the same settings?
THANK YOU!!!!
- FURRYe38Aug 29, 2018Guru - Experienced User
Under Advanced Tab, Advanced settings/Wireless Settings.
I believe IPv6 is usnder Advanced Tab/Advanced Settings...
Try the other port on the back of the satellite. I would also test the xbox wirelessly connected as well.
Making changes to router populates to satellite. I would also reboot the satellite and router as well.
