Funkyharlemite
Feb 27, 2018Aspirant
Orbi satellite connection
I have the one Orbi base - two satellite Orbi system. I have connected the base to my cable modem. The issues that I am having are the following: - When I arrive in my apt, the WiFi will say t...
tsig
Feb 27, 2018Luminary
Is the Orbi the only wifi device in your home? Do you have a router from you internet provider? Are you using a new SSID with the Orbi, or your old one?
- FunkyharlemiteFeb 27, 2018AspirantHi,
We have a cable ISP so the Orbi is connected to the cable modem. I have to check but i am using the SSID for the Orbi.
Just to provide a bit more clarity, when I get home the Orbi Wifi tab will have a ☑️ Next to it but when I go to browse, the browser will say, “you are not connected to the internet.” I have to turn wifi completely off on my device, then cut it back on and the Orbi will work after about 5 seconds.
How can it automatically connect and work without toggling the button on and off? Thank you- tsigFeb 27, 2018Luminary
Wondering if you are trying to connect to your previous wireless somehow. Did you turn off the wireless function from your other router?
- FunkyharlemiteFeb 27, 2018AspirantYes. The previous router was an apple airport. The issue is with the Orbi.
