Funkyharlemite
Feb 27, 2018Aspirant
Orbi satellite connection
I have the one Orbi base - two satellite Orbi system. I have connected the base to my cable modem. The issues that I am having are the following: - When I arrive in my apt, the WiFi will say t...
Funkyharlemite
Yes. The previous router was an apple airport. The issue is with the Orbi.
Feb 27, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
Do any other devices experience this after leaving the house area and coming back?
What is the device Mfr and model# your using that sees this issue?
You might try disabling Beamforming and MIMO and see if this helps any for when you leave and return home.
- FunkyharlemiteFeb 27, 2018AspirantI will turn the wireless functionality off on the ISP router and let you know what happens.
- FURRYe38Feb 27, 2018Guru - Experienced User
Ok sounds good.
Just curious, how close is the modem/router to the Orbi router? Distance wise.
