Funkyharlemite
Feb 27, 2018Aspirant
Orbi satellite connection
I have the one Orbi base - two satellite Orbi system. I have connected the base to my cable modem. The issues that I am having are the following: - When I arrive in my apt, the WiFi will say t...
Funkyharlemite
The Issue is not with the other modom as I would need a password to connect to it. Even though I see that modem as an option for connection I have never used that wireless connection.
There is no reason why I would be connected to the ISP modem, the issue is with the Orbi.
Feb 27, 2018Guru - Experienced User
Just wanna make sure that the ISP modem, if it has a router and wireless built in, that those features are disabled and the modem is bridged. Haivng a router and wifi built in and enabled with the Orbi router can cause problems. Just to check with you to make sure what this modem is is all.
