huffstar
Oct 21, 2018Aspirant
ORBI satellite connections RBS20
I just purchased an RBR20 and RBS20 combo from costco. I did this because my front door bell is having a problem connecting to my old router in the media room. I located the satellite close to the ...
Oct 22, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Also try turning down the 2.4ghz radio power output as well ON the router. Try setting from 100% to 50%. Found under Advanced tab/Advanced/Wireless Settings...
huffstar
Oct 22, 2018Aspirant
My firmware was updated when I installed the router so it is current for both the router and satellite. With all due respect, I appreciate your suggestions, but I refuse to try work-arounds to do something it should intrinsicly do in the first place. If I can't find a user friendly solution, I will simply return it for a refund and look for something that works the way I expect it. I bought the router compulsively which I usually don't do (maybe another lesson learned)
