huffstar
Oct 21, 2018Aspirant
ORBI satellite connections RBS20
I just purchased an RBR20 and RBS20 combo from costco. I did this because my front door bell is having a problem connecting to my old router in the media room. I located the satellite close to the ...
huffstar
Oct 22, 2018Aspirant
My firmware was updated when I installed the router so it is current for both the router and satellite. With all due respect, I appreciate your suggestions, but I refuse to try work-arounds to do something it should intrinsicly do in the first place. If I can't find a user friendly solution, I will simply return it for a refund and look for something that works the way I expect it. I bought the router compulsively which I usually don't do (maybe another lesson learned)
Retired_Member
Oct 22, 2018
OK....I was able to connect my 2.4G only weather station by turn down the power on 5G and shutting down one of the Sats. The 'work-around' above evidently has worked for others. Your understanding of the mesh system perhaps could have saved your frustration.
- huffstarOct 22, 2018Aspirant
I appreciate everyone's suggestions. I can't accept a solution that requires me to take action everytime the network may go down or power is lost. I expect all devices to connect where I want them when they come back online. This is simply a software issue that netgear can fix. I am surprised it is an issue in the first place. Their quality control and testing is flawed at best. I will be returning the router until a better solution is available (now or in the future).
- FURRYe38Oct 22, 2018Guru - Experienced User
Well once you make the changes, they will persist.
Others have mentioned that the issue of satellites and router not working right after a power outage seemed to be fixed in this version of FW...
Good Luck Though.
- Retired_MemberOct 22, 2018
Have you contacted the Doorbell Maker?
