ecarlson156
May 05, 2020Tutor
Orbi satellite connectivity issue
Please help me end my frustration. I have had "ok" internet for the past 5 months I've had Orbi AC2200 system, however over the past month it has been brutal. Devices lose connectivity all the time...
CrimpOn
May 05, 2020Guru - Experienced User
Oh, my. This is NOT what anyone needs right now (actually, ever).
Can you please describe the configuration?
- AC2200 is not an actual "model number". It is a measure of speed used for marketing.
- What modem is the Orbi router connected to (brand and model number).
This can affect how the Orbi works. - Is there a "pattern" to the problems? (daily? hourly? etc.)
Thanks
Beat1tle
May 06, 2020Aspirant
Press the sync button on the back of your Netgear Orbi Satellite which can help you Connect Orbi Wi-Fi with satellite LiteBlue.
- ecarlson156May 06, 2020Tutor
Thank you for suggesting pushing the sync button. I went through the "sync process" a few times and it still cycles to Magenta with frequency.
- BrucemanJul 08, 2020AspirantLimited coverage Company says up 6000sq’ coverage.
2 satellites are not recognized Used sync button useless
Why can’t they dumb this down so a normal human can use this simple to st up product? Lol- FURRYe38Jul 08, 2020Guru - Experienced User
What FW version is loaded on the RBR and RBS?
Be sure the FW is updated on both RBR and RBS. Both have to be on the same version.
Review the installation guilde on how to install and connect the RBR and RBS. Kind of simple for most average users.
