ecarlson156
May 05, 2020Tutor
Orbi satellite connectivity issue
Please help me end my frustration. I have had "ok" internet for the past 5 months I've had Orbi AC2200 system, however over the past month it has been brutal. Devices lose connectivity all the time...
May 06, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
Please try a factory reset and setup from scratch with the RBR and RBS.
Is the satellites on the same FW version as the RBR?
The RBSY won't be.
ecarlson156 wrote:Please help me end my frustration. I have had "ok" internet for the past 5 months I've had Orbi AC2200 system, however over the past month it has been brutal. Devices lose connectivity all the time. I even had a technician to the house and he said the modem is brinigng signal in fine, the router is not delivering signal properly. To try and resolve the issue, i bought an Orbi AC3000 satellite. Out of the box, I performed a sync, it connected blue, and then 2 minutes later went magenta, and then 30 seconds later, blue. And then 2 minutes later, magenta. I believe this same issue is happening to my original satellite. PLEASE HELP! Netgear support only responds to tickets once per day and I waited on hold 90 minutes for support today (to inform me the orignal satellite I bought was not compatible.) My wifi situation is a nightmare and I've dumped $600 into trying to improve it! I am running firmware V2.5.1.16
- ecarlson156May 06, 2020Tutor
No - I have not done a factory reset. When I do that - will I have to go into my "online Orbi Account" and delete the devices, and then re-add them?
- FURRYe38May 06, 2020Guru - Experienced User
No, just push the reset button in back for 15 seconds then release.
- ecarlson156May 07, 2020Tutor
Ok - here's the update. Thanks for the suggestion. I did a full factory reset last night and set up a new network. Both satellites are connected as well (reset them too). So the internet is better - actually perfect in one part of the house that is running off the router and original satellite. However in the part that geographically would be accessing the RBS50Y-200NAS - the service is slow with intermitten outages. On a mobile device it shows 4 bars of internet coverage, and the "Orbi Speed Test" shows "incredibly fast speeds" of 344 Mbs, however when I run a test from Optimum on the wireless in that part of the house, it shows 5 Mbs. I believe there is an issue with how the router is feeding this new satellite. Any suggestions?
- FURRYe38May 07, 2020Guru - Experienced User
Did you first disable the wifi radio on the mobile device then go near the RBSY and then re-enable the wifi radio on the mobile device to be sure it connects to the RBSY and not the far RBR or other RBS?
What is the distance between the RBSY and the RBR?
I did not disable the wifi and reconnect it. Just did that step and orbi test says 371 Mbps. "Speedtest App" says speed is 5.68 Mbps
Distance from RBSY to RBR is about 30 feet (and router is in basement and satellite is on 1st floor).
