jeff242
Jan 19, 2018Aspirant
Orbi Satellite dead after 2.1.2.18 update
I noticed that my Orbi satellite suddently stopped responding. I logged into the the router and found that it had automatically updated both router and satellite to 2.1.2.18 firmware. However, the...
- Jan 20, 2018
Replying to my own thread:
After hitting the reset button and holding it for one minute, there was still no light change. I unplugged and restarted the satellite, still with only a green powerlight and nothing else. After about *20* minutes I got a pulsing white ring. I then hit sync and synced from the UI.
First attempt the UI said "success" but the ring was magenta. Restarted the satellite. Second attempt the UI said "failure" bt the satellite ring was blue. Logged out and back into the UI and the satellite was found, but with 2.1.1 firmware.
I started the firmware update process, which downloaded fine, indicated it was ready to upload to the satellite, and proceeded. There were no errors, afterwards, the satellite reported in the UI as not being found/disconnected again. Right back to square one where I started.
Frustrated, I went to bed. Got up this morning, and the satellite is now alive, with the right firmware, and running fine. I am not sure what happened but somehow it sorted itself out.
sleepr88
Jan 21, 2018Apprentice
Netgear, since you can't seem to fix the Orbi, are you going to start issuing refunds? or exchanging everyone to Orbi Pros (which doesn't appear to have these problems, because you value business customers over regular consumers?)?
dpdurst
Jan 22, 2018Luminary
Class action lawsuit might be the way to go here.
- MarylandForceJan 22, 2018Tutor
I'm just a week over my costco 90 day return period and my orbi router and two satelittes are useless... these had previously worked pretty well for me over the first 90 days. I'm stunned that I am now dead in the water. I tried rolling back to the previous version and then to 2.1.1.12 without any reliability in my orbi's. Not sure what happened but this is crazy. I went to best buy and purchased velop in the meantime. It's not as fast as the orbi but it got me back up and running in the meantime. I am still pressing support to fix my orbis. too much $ for this to not work any more ... come on netgear, clearly us orbi users need some help.
- tagteamJan 22, 2018Virtuoso
Costco's 90-day return limitation does not apply to routers, such as the Orbi system.
