Stins
Feb 07, 2021Aspirant
Orbi Satellite: Devices disconnecting
Hi all, Wondering if you might be able to help me. I've been experiencing drop outs in connections from devices that are connected to the RBS50 satellite, this is both wired and wireless connecti...
CrimpOn
Feb 07, 2021Guru - Experienced User
Can you describe the "drop outs" in more detail? It sounds like the backhaul link is being interrupted
- StinsFeb 07, 2021Aspirant
Sure! So my work laptop (wireless connection) will drop connection from the satellite and connect to the router and then bounce back to the satellite momentarily later even though my work laptop is about 20cm from the satellite. The satelitte doesn't show any colour rings at the top to suggest something is wrong.
My Xbox connected via an ethernet connection to the satellite will disconnect and often kick me out of the game I'm in and again connect momentarily later - again there is no ring colours on the satellite to suggest anything is wrong.
