Stins
Feb 07, 2021Aspirant
Orbi Satellite: Devices disconnecting
Hi all, Wondering if you might be able to help me. I've been experiencing drop outs in connections from devices that are connected to the RBS50 satellite, this is both wired and wireless connecti...
MintChocolate
Feb 07, 2021Initiate
I’m getting the same thing. I upgraded to 2.7.2.104 last night and have had nothing but problems ever since. It’s extremely annoying.
Randomly, Zoom and Teams keeps dropping out. Never did that before the upgrade.
- cblaze22Mar 01, 2021TutorI have same issue. Just upgraded to that firmware and getting random drops bows and comes back up.
- FURRYe38Mar 02, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
cblaze22 wrote:
I have same issue. Just upgraded to that firmware and getting random drops bows and comes back up.- vajimMar 02, 2021Master
FURRYe38 wrote:Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
cblaze22 wrote:
I have same issue. Just upgraded to that firmware and getting random drops bows and comes back up.care to comment about the firmware issue?
If you'll do a search you'll see where there are lots of reports of disconnections using 2.7.2.104.
You may want to revert back to a previous version.
