Stins
Feb 07, 2021Aspirant
Orbi Satellite: Devices disconnecting
Hi all, Wondering if you might be able to help me. I've been experiencing drop outs in connections from devices that are connected to the RBS50 satellite, this is both wired and wireless connecti...
cblaze22
Mar 01, 2021Tutor
I have same issue. Just upgraded to that firmware and getting random drops bows and comes back up.
Mar 02, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- vajimMar 02, 2021Master
FURRYe38 wrote:Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
cblaze22 wrote:
I have same issue. Just upgraded to that firmware and getting random drops bows and comes back up.care to comment about the firmware issue?
- FURRYe38Mar 02, 2021Guru - Experienced User
Seen no problems with my Orbi on v104. Mine was factory reset and setup from scratch.
Even Parental controls work.
Thanks for asking.
