margieho
Aug 27, 2018Aspirant
Orbi satellite disconnecting intermittently
I have been using the orbi set since Jun. Things went perfectly in the first few weeks until July the satellite started to disconnect either from the main router or internet intermittently. Sometimes ...
Aug 28, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Have you factory reset the Satellite and re-added it?
- margiehoAug 29, 2018AspirantI managed to finally get in touch with NETGEAR Support by phone and it ended up their recommendation was to get my satellite replaced. Will read through the list FURRYe38 kindly provided and might try them out while I am waiting for the replacement. Thanks for all the suggestions!
