IppyD
Sep 22, 2018Aspirant
Orbi Satellite Disconnects on Youtube videos
I have a simple orbi set-up going - one router, one satellite.
Only when I watch videos on youtube, my satellite will crash (no devices can access the internet even when connected to the SSID) until the satellite is turned off. Other streaming sites work no problem (Netflix, Plex), it's only on youtube videos. How can I troubleshoot this issue?
1 Reply
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
