Shaun27's avatar
Jan 10, 2020
Orbi satellite disconnects
Hi I just purchased an Orbi 50 and a satellite. The satellite keeps disconnecting. It will flash white, then goes to blue and then reconnects. This units are only a week old. The router is fine.   ...
  • Shaun27's avatar
    Shaun27
    Jan 11, 2020
    Ok.
    seems the minimum distance between the router and satellite is 30 to 40 feet? So, the problem could well be they are too close.
    Will end the thread here
