ileodo
Mar 30, 2020Tutor
Orbi Satellite Drop Connection time to time
Hi, For some reason, my RBS50 Orbi Satellite dropped connection couple times a day. The synptoms are: 1. all the devices conntected to RBS50 Satellite dropped the connection (both Wireless a...
Mar 30, 2020Guru - Experienced User
What happens if you configure this with the RBS?
| ISP |
WAN v
+-----+-----+LAN +------------+
| Router +------->+ Switch |
WAN v
| RBR50 | LAN | RBS50 |
| AP mode |+----+| AP mode |
+-------------+ +-------------+ What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
- ileodoMar 30, 2020Tutor
Hey, many thanks for the reply:
I coudn't have the config you were proposing because there is no chance to have the cable to connect the router and satelitte.
My switch is Netgear GS108Ev3.
Beamforming, MIMO and WMM are all enabled.Daisy Chain, Fast Roaming, IPv6 are disabled and it's 40Mhz only mode.
I have tried the factory reset. it doesn't help.
- FURRYe38Mar 30, 2020Guru - Experienced User
Temporarily take the RBS to the same room as the RBR and connect the RBS to the RBR directly with a LAN cable. Does the RBS connect and sync correctly?
Your swtich your using is a managed switch. Be sure to disable ALL IGMP protocols and Green ethernet features. Energy Efficient Ethernet (IEEE 802.3az) compliant.
The RBS needs a more directly connection to the RBR. Parallel isn't recommended. The RBS needs to have a directly connection from behind the RBR. WIth or with out a switch.
- ileodoMar 31, 2020Tutor
My RBS and RBR can always been connected and synced successfully.
and the IGMP snooping on the switch is off. anything else i missed? is there a way to check the log of the router to drill in to the details?
