ileodo
Mar 30, 2020Tutor
Orbi Satellite Drop Connection time to time
Hi, For some reason, my RBS50 Orbi Satellite dropped connection couple times a day. The synptoms are: 1. all the devices conntected to RBS50 Satellite dropped the connection (both Wireless a...
ileodo
Mar 31, 2020Tutor
My RBS and RBR can always been connected and synced successfully.
and the IGMP snooping on the switch is off. anything else i missed? is there a way to check the log of the router to drill in to the details?
Mar 31, 2020Guru - Experienced User
Ensure Green Ethernet features are disabled on the switch.
Try the direct connection to see if RBS still drops connection.
Factory reset the RBS and re-sync it.
