ileodo
Mar 30, 2020Tutor
Orbi Satellite Drop Connection time to time
Hi, For some reason, my RBS50 Orbi Satellite dropped connection couple times a day. The synptoms are: 1. all the devices conntected to RBS50 Satellite dropped the connection (both Wireless a...
Mar 31, 2020Guru - Experienced User
Ensure Green Ethernet features are disabled on the switch.
Try the direct connection to see if RBS still drops connection.
Factory reset the RBS and re-sync it.
