ileodo
Mar 30, 2020Tutor
Orbi Satellite Drop Connection time to time
Hi, For some reason, my RBS50 Orbi Satellite dropped connection couple times a day. The synptoms are: 1. all the devices conntected to RBS50 Satellite dropped the connection (both Wireless a...
Anonymous
Mar 31, 2020bingo...........V2.5.1.8 firmware
ileodo
Apr 08, 2020Tutor
you think it's the firmware issue? which version you would suggest?
- AnonymousApr 09, 2020
ileodo wrote:you think it's the firmware issue? which version you would suggest?
Yes. Go to download area enter your model number
look for version you had before that was stable for you
all this other questions posted here are wasting your time
