ileodo
Mar 30, 2020Tutor
Orbi Satellite Drop Connection time to time
Hi, For some reason, my RBS50 Orbi Satellite dropped connection couple times a day. The synptoms are: 1. all the devices conntected to RBS50 Satellite dropped the connection (both Wireless a...
SW_
Mar 31, 2020Prodigy
This culprit here is Router WAN and Satellite LAN are on the same switch. Router WAN port and Satellite LAN port has to be on different network/switch. Take a look at this on How do I set Ethernet backhaul up on my Orbi WiFi System.
Connect Orbi yellow WAN port directly to ISP/Router LAN port, then get a 2nd cable and connect Orbi LAN port to the switch.
ileodo
Apr 08, 2020Tutor
My router and satellite are under AP mode, so i don't think there is any difference between WAN and LAN.
And actually i tried to connect the Router's LAN to the switch as well. doesn't work.
- FURRYe38Apr 08, 2020Guru - Experienced User
So if you have the RBR connected to the up stream router using the WAN port, connect the RBS directly to the back of the RBRs LAN port. Do you still see this problem?
- ileodoApr 08, 2020Tutor
seem like no, I'll give it a try now, and see if any process restared on satellite.
however, as per netgear official website, it's a valid setup to have both router and satellite connected to a swtich to have ethernet backhaul.. why it doesn't work well in my case?
Maybe the switch is the cause.
Seen issues with switches with IGMP protocols and green ethernet features cause problems between the RBR and RBS if one is in between them. Non managed and non green ethernet switches are prefer in between the RBR and RBS. I use HP Procurve 1400 series switches between mine.
